Spark Plug recommendations?
Old Oct 17, 2021 | 08:43 PM
F150HD's Avatar
F150HD
OEM. Only like $5 each. I keep a dozen on hand, they don't go bad.
Old Oct 19, 2021 | 09:17 PM
JimL_15 Electra Glide's Avatar
I personally use NGK in everything with no issue. YMMV.
Old Oct 19, 2021 | 09:57 PM
TwiZted Biker's Avatar
TwiZted Biker
Later model harley NGK or Nippondenso brands work very well. Use NGK platinums in the shovel.
Old Oct 19, 2021 | 11:46 PM
Eric Von Zipper's Avatar
Eric Von Zipper
Like oil, there are 11 refinery's and 7000 brand of oil.
Spark plugs are mostly made in china.
I do used the OEM HD ones, I like the HD symbol on them.
Old Oct 20, 2021 | 05:11 AM
Stiggy's Avatar
Stiggy
OP's bike, (like mine,) js an '02 early, carbureted Twin Cam with factory single fire ignition. No knock sensors, no 'computer.' I'm certain that these older bikes could care less what brand plugs they're running, as long as they cross reference to the factory Champion RJ-12's..
Later bikes? There maybe something to sticking with OEM as the bike (like many newer engines in general,) is more aware as to what's going on down in the cylinders.
Old Oct 23, 2021 | 04:18 AM
csonni's Avatar
csonni
Pulled both plugs last night. The first one was quite rich…sooty black and the other one was just about right. Not sure how one plug could be running so different unless it’s due for wire replacement.
Old Oct 23, 2021 | 03:05 PM
csonni's Avatar
csonni
I’m thinking that maybe I was running a richer plug because I replaced the loud lollipop baffles with V&H original baffles but one wouldn’t slide in all the way so it wasn’t in nearly as much as the lower exhaust pipe. Unequal back pressure maybe? I put the lollipop baffles back in and I’ll check the plugs in a couple of days.
Old Oct 23, 2021 | 07:40 PM
Rodent66's Avatar
Rodent66
Victory I had ran rich ( after pipes and performance chip ). It sometimes would foul a plug only on cold start, if they had couple thousand miles on them (Stock plugs or standard copper/plugs ). Switched to NGK Iridiums and never experienced another problem. Sold the bike w/several thousand miles and still ran/started great. I’m a big believer in them. They go in any vehicle I own. Best IMHO.
Old Oct 23, 2021 | 08:14 PM
Eastcoast Jim's Avatar
Eastcoast Jim
Ngk - dcpr7e
Old Nov 1, 2021 | 03:03 PM
csonni's Avatar
csonni
[size=13px]Delete this post[/size]
