PCIII software problems?
Old Aug 15, 2007 | 11:38 PM
SmokinEd's Avatar
SmokinEd
Default PCIII software problems?
Anyone else have problems connecting or downloading maps to their PCIII? I'm getting all kind of device errors, I tried downloading updates but now the commander module isn't even recognized. Tried all tricks from their site, seems like the one I have is a dud?
Anyone else?
Eddie
Old Aug 16, 2007 | 12:13 AM
StrGlide's Avatar
StrGlide
Default RE: PCIII software problems?
Be more specific on the errors.
Old Aug 16, 2007 | 12:14 AM
StrGlide's Avatar
StrGlide
By any chance did you attempt a firmware upgrade?
Old Aug 16, 2007 | 12:56 AM
SmokinEd's Avatar
SmokinEd
I did, no luck, after I upgraded the desktop software to 3.2.1, no connectivity at all. The package came with version 3.1.3 with the firmware at 2.1.1. Version 3.1.3 did not have the firmware update capability.There is an upgrade to firmware 2.1.2 but after upgrading the PC version I lost any connectivity to the module and couldn't do squat. Device errors were x0014 or something very close to that ... This is just wrong
Eddie
Old Aug 16, 2007 | 06:46 AM
nvsteve's Avatar
nvsteve
If you are doing this using the 9v adaptor the battery must be fully charged.
Old Aug 16, 2007 | 11:30 AM
Cruiser 1970's Avatar
Cruiser 1970
You can't do the firmware update with the engine running. Try it again using the 9v battery.
Old Aug 16, 2007 | 01:07 PM
iclick's Avatar
iclick
ORIGINAL: SmokinEd
As Gundog mentioned, don't attempt the firmware upgrade with the engine running. If you did that, it may take some time for the PCIII to recuperate, and will generate repeated errors until that time. In fact, my bike wouldn't even start after that, but at some point about 15 min. later it miraculously regained its composure and the firmware completed.
Old Aug 16, 2007 | 03:30 PM
glens's Avatar
glens
It's probably not a multi-tasking OS.
Old Aug 19, 2007 | 12:46 AM
SmokinEd's Avatar
SmokinEd
Turned out to be a dud PC III. Took it back, got a new one, and all is good!!!!
Thanks for the input all!
Old Aug 19, 2007 | 03:09 PM
T_Rob666's Avatar
T_Rob666
Same thing happened to me when I tried to do a firmware upgrade and I did everything as they told me to do, but the firmware I uploaded was bad. The PC wasn't being reconized or anything...ended up being bad firmware. They sent me a new PC...all is good now.
anubisss
Nov 1, 2008 09:50 PM
HDUltraRider
Aug 15, 2008 07:46 AM
gabhart
24
Jul 17, 2007 10:16 PM
jjr
May 28, 2007 01:15 AM
Ghosty
May 14, 2007 12:54 AM
