Wore out
Old Nov 18, 2023 | 10:07 PM
Shakeyja's Avatar
Shakeyja
Stage IV
Default Wore out
I have an 01 duece while riding the bike will loose power like the key has turned off then right back on the bike does this intermittently any ideas on what my problem might be
Old Nov 19, 2023 | 07:04 AM
bustert's Avatar
bustert
start looking for bad connections, bar kill switch and ignition switch.
Old Nov 19, 2023 | 08:06 AM
mskirwin's Avatar
mskirwin
Also check the grounds. Check to make sure battery connections are tight and clean.
Old Nov 19, 2023 | 08:39 AM
QC's Avatar
QC
Check your ignition switch. Happened to me and when I did this, I haven't had an issue since.
https://www.hdforums.com/forum/softa...le-riding.html
Old Nov 19, 2023 | 09:48 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I would guess battery connection first. Then I would go for ignition switch. Guessing vibration is making it off/on connection.
Does it have a carburetor? Could be fuel related.
You need to add a signature line so what variation of Harley you have
And for sure... Welcome, hope you are enjoying your ride here. And only as a suggestion, make your next new post over in the new member welcome area to say hello.
Old Nov 19, 2023 | 07:56 PM
Max Headflow's Avatar
Max Headflow
The connections to the main circuit breaker have become ohmic and they overheat the breaker. Look at the terminals and if they appear overheated, it probably a good idea to cut them off, re-crimp, and solder the wires to the terminals.. Replace the breaker.
Metsfan7557
Jul 20, 2018 10:00 AM
Ber9ie
Electrical/Lighting/Alarm
Aug 17, 2014 07:04 PM
Schnauzer
Jun 16, 2011 01:30 PM
randyeakin
Feb 24, 2010 04:29 AM
mark2flhtci
Sep 1, 2006 02:14 PM
