Headlight pulsing
Old Sep 28, 2007 | 05:28 PM
cocoaroading's Avatar
cocoaroading
Stage III
Default Headlight pulsing
About three weeks ago, my 03' RKing Classic's headlight starting intermittingely going from low beam to really low beam and then back to regular brightness again. This cycle happens about every 10 seconds. I have noticed that the battery is not as strong when starting the bike. I thought it might be a faulty auxillary light switch. I disconnected the switch. Any suggestions??????? My first thought was the regulator. Please give me some direction to head to.
Old Sep 28, 2007 | 10:56 PM
Doc 1's Avatar
Doc 1
Default RE: Headlight pulsing
Bad ground
Old Oct 4, 2007 | 11:48 AM
NCCopBikeRider's Avatar
NCCopBikeRider
Ditto bad/loose ground
Check the commom ground connection under the seat
Old Oct 13, 2007 | 05:31 PM
cocoaroading
Stage III
I took the seat off and discovered that both battery bolts had worked their way loose. Tightened up everything and no problems, Thanks guys!
Old Oct 13, 2007 | 05:51 PM
TazInCT's Avatar
TazInCT
I love happy endings
Elevatorman58
Sep 10, 2016 03:12 AM
svarnster
Mar 24, 2016 02:34 PM
duoglider
Feb 17, 2011 09:09 PM
bigbird883
Aug 15, 2009 10:42 PM
RobsSoftie
Jun 25, 2009 09:08 PM
