FLSTF charge woes
Old Oct 12, 2007 | 09:09 AM
Dan Clark's Avatar
Dan Clark
Stage II
Default FLSTF charge woes
Hi-new member here.I seem to be having a charging problem on my 2000 FLSTF.I had an original 7 yr. battery that went flat and asuming the age of it installed a new one.It let me down again.I've checked the stator output-good.I'm not quite so sure about the regulator.Any quick check here ?I also checked the terminals at the main 30-amp breaker,some corosion-but it cleaned up good.The bike starts good,runs great,everything works for about 50 miles until the battery goes down again.-Thanks-Dan.
Old Oct 12, 2007 | 11:07 AM
Dr.Hess's Avatar
Dr.Hess
Default RE: FLSTF charge woes
Start bike, with all the lights on, brake on, idling, what's the voltage across the battery? Rev to 2-3K, what's the voltage? Turn off bike. What's the voltage?
How did you test the stator output?
flhtc04
18
Apr 3, 2014 04:28 PM
mkelley7
Jun 19, 2013 03:13 PM
DR_DEUCE
Nov 6, 2012 04:41 PM
ryanlberg
Apr 11, 2012 04:10 PM
hucks 08
May 26, 2010 07:23 PM
