SERT fuel-air ratio
RE: SERT fuel-air ratio
You can have whatever you want but outside the 14.6 : 1 the O2 sensor feedback is not used.
If you have a near stock bike with just air filter and pipes you shouldnt need to get much richer than 14.1 : 1.
This can be achieved with the CLB tables and the VE tables and you can retain the O2 feedback which will adjust for minor atmospheric and altitude changes.
You could if you wish however run at 10 : 1 but you wont like it and it will wash your bores dry.
WB
WB
ORIGINAL: DRCLB
I'll be running a 103 kit with some headwork in the future.
WB
DRCLB: If you have the SERT,take a look at the User's Manual; it has good info fora basic understanding ofa/f, VE, and ignition timing; and,the range of adjustability available and what should be avoided.
Our bikes don't operate at a single a/f: the engine may need 12.8:1 at WOT at early rpms and something leaner as revs increase; it may need 13.8 while accelerating at less than WOT; etc.
Also, the narrowband 02 sensors are not what limits the bike's ability to adjust a/f automatically; it's HD's ECM programming that simply takes thesensors off-line so to speak.
ORIGINAL: Harleypingman
Also, the narrowband 02 sensors are not what limits the bike's ability to adjust a/f automatically; it's HD's ECM programming that simply takes the sensors off-line so to speak.
The result of the multiplier is indicated in the SERT data-logging software by the "VE New" value.
It's the best way to "autotune" with narrowband O2 sensors. Word is that the function (at least for H-D) was first put into use in the Buell line, some time ago.
It does not negate the necessity of having the VE tables accurately populated. In fact, it relies on that.
The multiplier evidently can only be manually reset to 100% via the Digital Technician interface.
Lopoetve
11-28-2008 07:16 PM
