SERT tune without dyno?
There is a Datalog program in EVERY SERT. You Hook a laptop to the SERT, with datalog running on the Laptop. And ride the bike for up to one hour. Riding through various throttle /RPM / Load conditions Etc. Come back and analyze the Data. Look for spark knock retard, And adjust the Cells that are needed. However this does not read AFR. But will tune any bike good enough for the typical rider. And you will get a better MAP than most DYNO tunes because this is actual riding conditions. It may take a few rides But if you have a SERT and a laptop. It can be done. There is also a great data capture unit on the market. Where you do not have to use a laptop. It is a DTT twinscan 88+, Which captures all the same data as the laptop and is much smaller. Just plug it into the ECM and ride, and return and download the data to a pc. This must be used in conjunction with a SERT. Which this is a open loop EFI system. Meaning that it does not self adjust from data received from o2 sensors. But DTT also has the market on that. They have a new closed loop system that will self adjust the ECM when any changes are made like pipes or baffles, Air cleaner/Cams/Etc. But you have to have two o2 sensors welded into your Head pipes. Approx 6" from the head. That retrieves the actual AFR readings. And Compensates up to 25% It is called VRIF-D or something like that.
Search Daytona Twin Tech and go to their site.
The day of the Dyno tune will be over soon. It is way too expensive. And if you do not have a great tuner. You can do better with a DTT/SERT combo or a DTT TS 88+ / Closed loop system.
And have a perfect tune every time. It is expensive, Maybe the cost of two Dyno sessions. But I am going to go with the Closed loop system when I can afford it.
Change pipes= self healing
Mod Baffles = Self healing
High flow AF = Self healing
Tempature =Self healing
THAT WOULD BE GREAT!!!!
And no , I am not a salesman or anything, Just excited that I am learning about the HD EFI system. And the new stuff on the market to fix HD screw ups that the dealer wants to Rape you for!
I am getting ready to take my laptop for a ride, And tune my own bike! Isn't life SWEEEEET!
Oh, BTW a great DYNO tuner can squeeze another 1/2 HP out of her with several HRs tuning. But unless you race for a living???? IS IT REALLY WORTH IT?
AFR = Air Fuel Ratio ( Just in Case)
Obviously, you donât strattle your laptop in your lap while your riding. But do you just smiply bungie it to the pillion and go for it?
i have ridden around with one in my saddle bags with no problem!! but, it is a old laptop that is not worth much$$
that being said, the daytona (DTT) 88+ scanner is way better!! get it and wego and you can make your own perfect map everytime! or as vrock stated, do the closed loop system....as i understand it thats what all the 07 harleys have now??
Thanks for the info. I'll research a wego and a (DDT) 88+ scanner.
https://www.hdforums.com/m_669361/tm.htm
Then go with Data Logging for fine tuning if you think you need it. Just my suggestion.
What is a wego anyway? I've read several posts about a wego snifing the exhaust? I only have a work laptop and they'll like shoot me if I crash the hard drive :-)
