Understanding SERT tuning/data .
Here is a question, trying to be sure I understand the SERT.
I have an '03 FLHT, 95" stage II, SE 203 and true duals.
I am playing with the tune to see if I can eliminate the surging at low Map and low RPM and maybe improve the MPG (only about 34 on the road). I have been playing with maps and data modes, excel spread sheets and data modes and seem to be making no progress.
I have thought about it and....
Since there is no feeedback loop on this system -- AFR to ECM, I suppose there is really no way to effectively tune. All data collected in "data mode" must be calculated based on the table input that I assign to the file. I am guessing that the ECM takes the TPS and RPM and does a table look-up to determine Injector pulse, and timing. It probably also takes the engine temp and does some other look-up for cold conditions or hot conditions.
Either way, the data out (collected in data mode on the SERT) is the result of the look-up and then somes calculation. If this is the case, then what value does a SERT have without a dyno and AFR data?
Maybe I am soaked and need to go back and read the manual again. I suppose that with some device that read AFR and collects data at TP and RPM, the bike could be tuned without a dyno. But this then would take a ton of time.
Only logical option would be to start off with a close map and run the bike on a dyno for about 8 hours.....
Anyone care to straighten me out...provide some feedback. Can the garage mechanic with basic tools really tune a bike using a SERT? And can it be tuned to run better that the std HD maps that are provided with the SERT?
AW
Gearhead
A good dyno operator and SERT tuner can dial in your bike in 4 to 5 hours and thats time taken to load and unload on and off the dyno. Trying to do this with out the proper data (Afr feed back under a load in a controlled environment) will be wearing out the tires before you get a tune.
AW
