Starter/Solenoid
Old Nov 29, 2007 | 09:21 AM
BADCUDA's Avatar
BADCUDA
6th Gear
Default Starter/Solenoid
I have a stock 87 Heritage with starting problems. It has a fully charged battery, but I have to hit the Start
button many-many times to get the starter to engage. Once the clickfest is done, the bike cranks well
and starts. All lights are bright and bike runs great. Sounds like the solenoid is just clicking. I've changed the relay.
Some days it takes 30-40 clicks to get it to catch. Any ideas ???
Thanks
Old Nov 29, 2007 | 10:09 AM
underboss's Avatar
underboss
Default RE: Starter/Solenoid
I'd say the washer on the soleniod plunger is not making contact with the two lugs
that bridge the gap from the battery to the starter motor.
Old Nov 29, 2007 | 11:21 AM
BADCUDA's Avatar
BADCUDA
6th Gear
Is that an easy fix or does that mean a new solenoid ?? I figure stuff is going to start going bad, 20 years
old but only 11k miles.
Thanks
Old Nov 29, 2007 | 12:30 PM
underboss's Avatar
underboss
You can rebuild a solenoid - there are kits that consist of a new washer and lugs. I'm not sure what else is in the kit, maybe a new spring. A solenoid will cost probably $60-$80.
Or take it apart, turn the washer over, make sure the plunger moves freely inside and put it back together.
Summers420us
EVO
30
Feb 22, 2023 03:10 PM
sech4787
Apr 10, 2018 05:24 PM
jsbridgew
EVO
14
Jun 24, 2016 05:49 AM
irydasteelhorse
EVO
Feb 22, 2014 10:00 PM
TexasCowGrower
Feb 18, 2011 02:50 PM
