Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I need to order a new connector...It isthe gray Molex M-150 (8-pin) connector. The wire harness is routed down the left side and feeds the left handlebar controlswitches.
Thanks for the part #'s...I doubt the dealer will have in stock, but worth a shot!! I wanted the part #'s, because it would be easier to explain to them!!
When I was working on my handle bars I needed a couple of pins for one of the connectors. The dealer was the one that had that style of plug and the pins in stock. You can get them from J&P Cycles also, I don't know how soon you need them.
