SERT Self Tuning question
Old Feb 28, 2008 | 05:43 PM
  #41
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: SERT Self Tuning question
ORIGINAL: Steve Cole
One needs to remember that the HDECM is produced down the same assemble line that the GM marine ECM is made. Let's just say they share a fair amount of hardware between each of them. The new 2008 DBW ECM event switches to the same connector GM has been using for years. The Knock method has always been remove first and add back. When tuned properly it works pretty well this way.
Now this makes sense since marine engines see suchtremendous loads under hard acceleration high torque conditions. Take my 16,000 lb SeaRay from dead stop and hard throttle it up on planein 5-7 foot waves on Lake Erie. Then imagine a fully loaded (two up)bagger throttling up in second gear from a3 mph roll at a stop light that just turned green. Probably the same type of load dynamics on the engine.
Old Mar 4, 2008 | 03:14 PM
  #42
whittlebeast's Avatar
whittlebeast
I have a new question.
You set the entire AFR map to 13.2 and do the perfect tune thru the entire VE map to 13.2 AFR
You set the entire 70 KPA column of the AFR table to 14.5 AFR
Now you set the entire low load section of the AFR table to 14.6 to force closed loop
Youmax outthe o2 bias table to force the entire center of the map to 14.2 AFR
You go out and drive the bike for a few hundred miles to get the ADF and ADV homed in on some new answer that you cant see from the SERT software.
now you get the motor to 70 KPA back on on the dyno
The question is:
Will the code attempt to hit 14.5 AFR as you see in the AFR table and actually go leaner (remember it was at 14.2 due to the biasing)
OR
will the code try to hit 14.1= (14.5 / 14.6) * 14.2
OR
will the code try to hit 14.1= 14.2 - (14.6 - 14.5)
OR
some other answer
AW
Old Mar 4, 2008 | 06:13 PM
  #43
Shovelhead Bob's Avatar
Shovelhead Bob
Any value OTHER than 14.6, the bike is out of Closed Loop...
That is the "Switch" to activete the CLB in that zone.....
Any value less than 14.6, that is what will be generated, providing that the VE's were dialed in to the DESIRED AFR....
Old Mar 4, 2008 | 06:59 PM
  #44
whittlebeast
But.....
If the entire VE table was perfect I think First the 02 Integrater wouldjump to 1.035 everyware, theAFT would in migrate to 1.035 everyware in an attempt to get the 02 integrator to an average of 1. Last the code slowlyslides the AFT to a 0 average and the code moves the 1.035 to the AFV.
Now when the AFR table finds 14.5 AFR(open loop mode)it still uses the 1.035 AFV and winds up at 14.5/1.035 and ends up at 14.01 AFR
This would also happen also at WOT so if you really want 13.0 AFR you have to set the targets at 13*1.035 or 13.5
It may bepartlywraped upin that hidden, pesky, non resetableand non viewable AFV.
note: if you look at a SERT data log when the motor is in open loop, the VE New is still not the same as VE. Something ischanging it.
I hate not having full and total access to the programmers. This is the logic part of the Megasquirt that I worked with the programmers every day to get the code rock solid. I always took the side "If we can't explain it in the manual, we can't expect people to tune it."
AW
Old Mar 4, 2008 | 07:53 PM
  #45
whittlebeast
Here is an example. Notice that for the most part I amin open loop but VE is not always the same a VE New
Way cood stuff but I am still confused.
AW
Old Mar 5, 2008 | 12:34 PM
  #46
Steve Cole's Avatar
Steve Cole
HD EFI Guru
ORIGINAL: whittlebeast
AW
When setting the bike up and when tuning the O2 bias table after the fact your going to get different results. The ECM is going to learn when in closed loop then apply what it's learned event in open loop. You need to start doing the basic stuff and see the results and quit jumping to conclusions about whats is going to happen. As I told you on the phone and again here it's not a mega squirt and it works differently.
Old Mar 5, 2008 | 01:37 PM
  #47
whittlebeast
Most of the self learn and target AFR stuff works quite a bit different in the MS world. I agree.
I am just trying to get my head around how this system works. As I always tell the programmers over at MS, "If you can't explain it in the documentation, they can't tune it. So how are we going to explain that one?"
AW
Old Mar 5, 2008 | 02:40 PM
  #48
whittlebeast
We got the sert log viewer working today
It is available for free download from http://www.ncs-stl.com/sert/MegaLogV...tup-Harley.zip
also download http://www.ncs-stl.com/sert/test12.DM2This is the sert data file
and http://www.ncs-stl.com/sert/SertOutput12.csvThis is the sert output file that was created that can be loaded into the viewer
Here is a screen shot from the viewer off my bike
Have fun
AW
Old Mar 5, 2008 | 09:07 PM
  #49
Steve Cole's Avatar
Steve Cole
HD EFI Guru
The only way to "get your head around how it works" is to go out and start useing it. Then spend the time to review the data. Your not going to do it by sitting down and looking at the same old data the same old way. It's different and needs to be treated different.
Old Mar 6, 2008 | 06:40 AM
  #50
whittlebeast
I choose to develope the tools to review the data first and develope the stock fuel and timing maps. Harley elected to
not include the factory original maps making it very difficult to return a bike back to stock without the help and mercy
ofthe dealer network. They are in the business of selling shop time at $100/hr.
When you want to change the wheels and tires on your car the first two thing you go find is a lug wrench and a jack.
Without those two tools nothing else in the project matters. When I build aracecar, I first design and prove the entire
concept in FEA.The number of options and pitfalls of chassis design is impossible to comprehend without access to the
tools to locate the pits. EFI tuning at home is similar. Purchasing a dyno is out of the question to tune one bike. I
would never be able to afford the dyno time at a dealer,required to get my bike to the level of drivability I demand. I
have been there, done that. I can do it again with agood set of tools.
The guys from MSconverted the MS data logger in about 30 lines of code. Everything was designed to be adjustable
from day one. The next release available for free from http://www.efianalytics.com/MegaLogViewer/will include the option for
reading Harley Delfi data log files.
AW
