Code p1351
Old Feb 4, 2008 | 06:02 PM
1goindiesel's Avatar
1goindiesel
Default Code p1351
05 fatboy, limped home on rear cylinder only. put new coil on. still no go. Shows code p1351. any ideas-help. Something simple? Take it in to stealership? Thanks in advance.
Old Feb 4, 2008 | 06:20 PM
Doc 1's Avatar
Doc 1
Default RE: Code p1351
1351 is 'front ignition open' no spark, if you replaced the coil and still no spark check your compression. If the crank position sensor doesn't see compression in the cylinder it won't deliver a spark or an injector pulse, the cylinder will be dead.
Old Feb 5, 2008 | 10:29 AM
1goindiesel
Thanks Doc, I had not considered that. I have a suspicion it might be an injector failing as when it happened it sputtered between normal power and one cylinder limp a few times before settling on running just the rear cylinder. Once the crank sensor would go out it would just be gone wouldnt it?It also showed a 260-series code which I think is something about injectors. Your opinion still the same?
Old Feb 5, 2008 | 11:02 AM
Doc 1's Avatar
Doc 1
0261and 0262 is a high/low front injector code so that would change my my diagnoses
Old Feb 6, 2008 | 09:31 AM
1goindiesel
Thank you, I appreciate your help.
Papa Georgio
Apr 21, 2023 02:01 AM
twistedgrip
Sep 6, 2018 08:29 PM
harleyman6971
Sep 8, 2013 03:31 PM
longrider1956
Exhaust System Topics
May 30, 2010 04:09 AM
flaw42
Aug 8, 2007 12:39 PM
