Found it!!!!!!!
Old Feb 22, 2008 | 01:03 PM
Greydawg's Avatar
Greydawg
Default Found it!!!!!!!
It took some doing but I finally found where the short was in my passing lamps.
(https://www.hdforums.com/m_2848315/tm.htm)
The wire harness coming into the fairing was rubbing on the radio.
The hot wire to the lamps rubbed through and every time I hit the switch, it shorted out.
Two zip ties, to pull the wires away from the radio,and a spot of liquid tape fixed the problem.
(I just couldn't get in there with regular electrial tape.)
I'm only posting this in the hopes that if anyone else has this or any other electrical problem
concerning lights in front of the bike, perhaps this will give them a place to look.
Here's a pic.
Look at the grey wire above my finger, the black dot is the burn mark/short that was causing my problems.
Hope this can help somebody sometime.
[IMG]local://upfiles/52411/C461333CA2EA48EBAE5570D479A98C23.jpg[/IMG]
Old Feb 22, 2008 | 02:07 PM
rjmac53's Avatar
rjmac53
Default RE: Found it!!!!!!!
Good for you GD. I know it's gotta be a load off your mind. The needle in the haystack.
Old Feb 22, 2008 | 07:47 PM
Trucky911's Avatar
Trucky911
Nice find GD. I bet the dealer would not found it after being there 3 or 4 times...
Trucky911
Old Feb 22, 2008 | 08:04 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: Trucky911
Trucky911
No way the dealer would have never found it. They would have replaced the harness.
Old Feb 23, 2008 | 12:11 PM
davidwideglide06's Avatar
davidwideglide06
Good find!! I bet you feel better, as that stuff will drive you nuts!! Atleast it does me. Thanks for posting what you found. Even if it does not help someone today, I am sure it will for someone later when they do a search.
Old Feb 24, 2008 | 07:59 AM
Greydawg's Avatar
Greydawg
Thanks for the replies.
Yes, it did drive me nuts![:@]
And I wasn't about to spend a fortune at the dealers to do something I felt I could do myself.
It would've been a Hell of alot easier to just run a new wire from the switch to the "Y" connenctor, but quite frankly , I'm pretty **** about stuff like that.
I need to know what and why something's happening.
One other thing I noticed when I was inside the fairing.
The 4 wires going to your instrument panel lights lay directly on top of the radio.
Granted there are no sharp edges for them to rub on, but I think I'll wrap some electrical tape around them to insulate them a bit better.
Gives me peace of mind.
Oh, did I mention how **** I am????
Old Mar 3, 2008 | 06:35 PM
Yardstick's Avatar
Yardstick
If you wrap the wires with electrical tape....get the kind that is thicker...almost padded. That tape withstands alot of abuse. I know from first hand experience when I rewired and headlight and switch on a chopper and pinched the handlebar wiring.
Smash
Sep 29, 2015 05:19 PM
Motor City Street Glide
Mar 13, 2012 10:35 PM
Telefishin2k
Oct 16, 2007 02:13 PM
millercm
May 4, 2007 11:05 AM
PhantomMaxx
Aug 28, 2006 04:14 AM
