only one sert question
Old Mar 9, 2008 | 07:40 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
Default only one sert question
how can u get any ritcher than 14.2-1 while using harleys narrow band 02 sensors?
Old Mar 9, 2008 | 07:43 PM
whittlebeast's Avatar
whittlebeast
Default RE: only one sert question
In what situation are you looking for more fuel? What problem are you trying to solve?
AW
Old Mar 9, 2008 | 07:44 PM
bigdumbnoitall00
HEAT!
Old Mar 9, 2008 | 07:45 PM
bigdumbnoitall00
not mention pinging stumbbling
Old Mar 9, 2008 | 08:03 PM
whittlebeast
Does this bike have the stock ECU/map Is there some sort of o2 resistor device to get to 14.2?
Old Mar 9, 2008 | 08:46 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
You can get to any fuel mixture your looking to get to with the SERT. Just set the desired AFR to the ratio you want once it's been properly tuned. The 14.2 limit is about as far as you can go and still keep it running in closed loop but that's not a big deal. Remember they've been running in open loop since 2001. If you tune the system properly 14.2 should be more than enough to keep it cool.
FX4
Jan 14, 2011 05:38 PM
Mountainkowboy
Aug 16, 2009 09:33 PM
FXDI35
Mar 2, 2008 02:53 PM
huey408
Dec 1, 2007 04:06 PM
nada1
Jan 2, 2007 01:30 AM
