Throttle Wire
Old Mar 19, 2008 | 10:00 PM
StrokerD's Avatar
StrokerD
Stage I
Default Throttle Wire
I'm wanting to put 18" apes on a 2008 Road King 110 Screaming Eagle.Will there be an issue with extending the wire for the throttle.
I know there is an issue with the fittings for the brake line fittings, no one makes them yet from what I've been told.
Old Mar 20, 2008 | 10:19 AM
Peppa1's Avatar
Peppa1
Default RE: Throttle Wire
There are a few companies out there that are making the wiring extensions so you shouldn't have a problem. I think there is a piece that goes to the FBW harness that you may need to get. Check with dawg here at the forum he can give you the correct part # for it.
Old Mar 20, 2008 | 10:25 PM
Bertk's Avatar
Bertk
NAMZ Custom Cycle Products is one company that sells the extension kit.
MILLER41143
Jun 10, 2024 03:27 PM
Flhrhog
Feb 8, 2016 10:46 PM
Woodys03
Feb 13, 2015 05:52 PM
Rick06
Aug 29, 2009 02:15 PM
