Which EFI system do I have ???
Old Feb 8, 2006 | 10:55 AM
Nitehawk's Avatar
Nitehawk
Default Which EFI system do I have ???
After reading through alot of great info here I am unable to figure out which System I have on my 06 Ultra, which I purchased in Aug of 05, so I was wondering if all 06 Ultra's have the same fuel injectors or did they use the CVO's up to a certain point, I am gonna call the service Dept to schedule reflash to try and take care of my cold stalling issues as well as have them update the radio software from ver.7.4 to V7.8, I wasn't sure if I could look at my VIN to see when it was built and then find info on when they started installing the smaller injectors......
Old Feb 9, 2006 | 10:20 AM
HDF Tech's Avatar
HDF Tech
Default RE: Which EFI system do I have ???
In an 06 you probably have the smaller injectors due to EPA regs. You may look on the frame under the seat right behind the end of the tank for the production date. It's usually stamped into the frame there. The CVO injectors seem to deal with the leanness of the 06 bikes because of more fuel delivery. Your system is a delphi system also.
jgcable
Aug 21, 2014 11:45 AM
Custom07RKC
Mar 10, 2007 11:43 AM
carsoni
Aug 24, 2006 06:46 PM
DyNaBoB
May 29, 2006 04:08 PM
HDF Tech
General Topics/Tech Tips
Feb 22, 2006 04:07 PM
