Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have an 06 Street Glide.. I bought the badlands module,an a set of Technostalgia led rear tail lights(39 ford tear drops). So here's the problem i can't get the leftside to work(no running,brake or turn) I'm fustrated!! This is what i've done so far to chase the issue..(A)Swapped out the badlands control with another thinkin maybe a bad control (B)Both lights are good i can swap side to side an they both function(C)checked factory output plug with ohm meter an the badlands module..every thing has power flashes/brakes correct(D) was told the front lights must be connected to get this unit to work.. they are even if i unplug them the right side does all its stuff
(E) I'm still running the standard factory bulbs in the front..and its not connected to the module, i was told this is proper Bottom line is i'm at the end of the rope i'm no electical wizard.. but know enough to get by an this project shouldn't have been this hard.. Any info or input would be a great help at this time.. Thanks
