Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Firts sorry for my bad englihs, I´m from Barcelona, Spain
I install yesterday a new Thundermax autotunig in my 2004 FLHTI
The bike have some upgrades
EVENT NUMBER
ITEM DESCRIPTION
16549-99
1550 CONVERSION KIT
22661-99A
KIT, 1550 PISTON
25149-00
SE 204 CAM KIT
25938-00
ROLLER BRG UPRGADE S
29775-02A
1550 ST2 EFI KIT
0405-3508
TRU DUAL HEADER L85
N41402
PEACEMAKERS EXHAUST
But i have some problems
i charge the 376 MAP , and first all is well butin a secons the bike idles at 2500rpm. It will come down to 1200 rpm for a few seconds sometimes but then will just idle back up to 2500 rpm!! and some timego up to 3000....
when i run in the hight way, the idle made the same .... go up to 2500rpm and i can drive with-out hands ..... 50-60Mh... (and i dont have installed the cruiser.... :-(....¿?¿?¿
Thank you for your support and experience, i wait your coments...
You need to clear your IAC offsets and go thru the initialization process again....read the instructions carefully.....don't touch your throttle during the process....good luck
You need to start over. Follow the directions to the letter, or it won't work as it should. Check all your settings and write them to the module. Engine must be cold before intializing to work correctly. As kdietz mentioned, clear learned iac points first, or nothing will likely change with your rpm. Ron
