SERT 08 DYNA
Old Jun 2, 2008 | 06:43 PM
BenjaminLHarris's Avatar
BenjaminLHarris
Stage IV
Default SERT 08 DYNA
Hello All,
I just picked up the SERT for my 2008 Dyna, and I love it. I was able to flash the ECU with a map that fits what I am running, and I was able too fine tune it from there. I think this is easier than working on a carb; or very similar. It just requires using a computer instead of a screwdriver.
Has anyone tried running wide band 02 sensors with the SERT? I would like to know if you had any luck with them, and what kind of difference it made for you.
Thanks
Ben (DOC)
Crescent City, CA
Old Jun 2, 2008 | 06:58 PM
Doc 1's Avatar
Doc 1
Default RE: SERT 08 DYNA
The Delphi ECM doesn't read the wide band 02 sensors, the 02 sensors that the ECM reads are a narrow band switching device which sends a voltage to the ECM by a chemical reaction. This voltage (Bias Voltage) is then analized by the ECM and then a targeted AFR is sent tothe injector. (in simple terms)
Old Jun 2, 2008 | 07:05 PM
BenjaminLHarris
Stage IV
Good to know. Thanks. I wasn't sure if the ECU would recognise the wideband O2 sensors. I guess I'll just keep hitting the books. I need to learn more about these new systems.
Ben (DOC)
Crescent City, CA
jmg343
Jun 18, 2009 07:52 AM
Roadhog02
Apr 1, 2008 08:56 PM
bigdumbnoitall00
Exhaust System Topics
Mar 9, 2008 06:58 PM
Wide06
Oct 7, 2007 03:43 AM
XXXRacing
Nov 15, 2006 01:57 AM
