SERT map question 2006 Dyna
Old Jun 6, 2008 | 08:12 PM
blueglide88's Avatar
blueglide88
Default SERT map question 2006 Dyna
I have a 2006 Dyna that I recent\\;y changed pipes on. I had the SE air cleaner and SEII exhaust and a 141NX104-A0 downlaod map. I put the new SE mufflers on that are quiter and I believe EPA legal. My highway mileage went down from high 40's to apprx 40mpg. This is cruising at 65mph. I'm also getting a bit more knocking. Is there a&nbsp\\; download for this combination of AC and muffler? I bought my SERT when I bought the bike and the new mufflers were not out yet. Dif HD ever develop a map for this? How can I get one without buying a new SERT?
Old Jun 6, 2008 | 08:28 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: SERT map question 2006 Dyna
http://www.mastertune.net/&nbsp\\;To get the most current map (141NX104-BO)
&nbsp\\;
http://fs04n1.sendspace.com/dl/9165e...TUNER_V477.zip
&nbsp\\;
To get the newest software version.....
&nbsp\\;
You don't need a new SERT, just updated software...
Old Jun 6, 2008 | 10:43 PM
blueglide88
Thanks for the link.
&nbsp\\;
Looking thru the pdf file I do not see the configuration I'm looking for. Let me try to be clear. SE air cleaner, and the SE mufflers 80492-07. Is map 141NX104-BO configured for SEII mufflers, or the newer SE mufflers?
&nbsp\\;
I took off the SEII mufflers because I wanted a little less noise on long trips. But if my mileage is going to suffer, I'll put the SEII mufflers back on.
Old Jun 6, 2008 | 10:56 PM
Shovelhead Bob
The map is the SAME as the one you are currently running, except that it has been updated in the spark tables and VE's....
&nbsp\\;
Your choice of mufflers is irrelevant for this particular map....
&nbsp\\;
Essentially, this map was designed for the SEII mufflers, but will work a little better with the LEGAL SE mufflers, as there is a bit more backpressure to aid in scavenging.....
&nbsp\\;
88", 25 degree injectors, SEAC and SE Mufflers... map #59.....
BK2
Jul 20, 2008 05:54 PM
BK2
Jul 15, 2008 02:12 PM
BK2
Jul 13, 2008 10:54 AM
ruostekasa
Jun 24, 2008 12:12 PM
Solitario
Jun 1, 2008 03:35 PM
