Thundermax on '08 Dyna
Old Jul 8, 2008 | 08:43 PM
bstupar's Avatar
bstupar
Stage II
Default Thundermax on '08 Dyna
I just installed a Thundermax ECM with autotune on my '08 Dyna.&nbsp\\; Everything installed fine, except that the 6th gear indicator doesn't work anymore (this seems to be a common issue).&nbsp\\; It looks like I just need to adjust the Final Drive Ratio and/or Gear 6 Min TPS values - right now I'm using the default values in map 403 of 84 and 40.&nbsp\\; If Gear 6 Min TPS is really the minimum throttle position (40%) that allows the 6th gear indicator light to come on, I suspect that's the problem - I wasn't over 40% throttle in 6th on my test ride.&nbsp\\; For those who have already gone through this exercise, what values did you settle on for the Final Drive Ratio and Gear 6 Min TPS ?
Old Jul 8, 2008 | 09:07 PM
rbabos's Avatar
rbabos
Default RE: Thundermax on '08 Dyna
The light should come on at around 40 mph, not 40% as you would think. Do you have the latest firmware 6 version ? If not, that could be the problem.
Ron
hamiltont55
Jul 17, 2019 07:45 PM
turk55
May 2, 2015 04:37 PM
BIGVTWIN
Oct 19, 2012 05:00 PM
frankjake
Jan 5, 2009 11:00 PM
harley-jones
Sep 16, 2008 03:56 PM
