Fuel hose leaking
Old Jul 19, 2008 | 12:14 PM
bigstevex4's Avatar
bigstevex4
Default Fuel hose leaking
on my 98 RK inj . the back hose from tank to TB leaks around the swival new hose is a 105 bucks
But comes with the swival off there is an o ring in there but cant get the swival off mine. Is this some kind of compression fitting or ??? tank end
Old Jul 25, 2008 | 10:06 PM
jaxhd1's Avatar
jaxhd1
Stage I
Default RE: Fuel hose leaking
I just replaced the o rings in my tank fitting,,
It is a quick disconnect fitting( just pull up on the tank side of the fitting and the hose should pull right out) and the dealer told me that the o rings can't be replaced but it worked for me,
I used a 9/16 OD x 7/16 ID O ring
Austin Dave
Jun 1, 2012 10:18 PM
beemer737
Exhaust System Topics
Aug 25, 2010 05:53 PM
tgarrett1
Jul 8, 2009 08:53 AM
CMAchris
Jan 5, 2009 02:02 PM
rustyed
Jan 6, 2007 12:43 PM
