Starter Problems
Old Mar 15, 2006 | 12:02 AM
Jim Wurbel's Avatar
Jim Wurbel
Stage III
Default Starter Problems
Have a 95 Heritage. Starter will not engage. Have replaced relay and have put in a new starter I had previously. I have bypassed relay with jumper and starter engages. When I hit the starter button on handlebars, I can feel the relay and solenoid try to engage but nothing happens. Battery has been tested off of bike and is OK per Harley. They had bike when originally problem started and could find nothing wrong. HELP!
Thanks.
Old Mar 15, 2006 | 12:53 AM
100yrfatboy's Avatar
100yrfatboy
Default RE: Starter Problems
Not to ask a dumb question, The engine isn't locked up is it? Otherwise I don't have a clue.
Old Mar 16, 2006 | 12:56 AM
Thorns's Avatar
Thorns
Best way is to check your voltage through the relay, and at the starter with a voltmeter. Then you can disconnect wires and check with an ohmmeter(frayed or broken wire) from the starter button. What happens when you bypass the starter button with a jumper wire? Check it in steps.
Thorns
Old Mar 18, 2006 | 04:30 PM
Jim Wurbel's Avatar
Jim Wurbel
Stage III
Thanks for the reply and no the engine isn't locked up. I have bypassed relay with jumper and starter works OK. I'll try your other suggestions and thanks
Old Apr 16, 2006 | 12:48 PM
Interceptor2k's Avatar
Interceptor2k
Stage I
Did you ever find a fix for this? My neighbor with a 94 Ultra Classic has the exact same issue.........
garystaven88
Electrical/Lighting/Alarm
Oct 25, 2015 11:39 AM
kevinviz
Mar 6, 2013 11:57 AM
shiznits75
May 20, 2010 12:33 PM
dirty78ironhead
Ironhead
May 20, 2008 04:49 PM
glide1996
May 28, 2007 01:39 AM
