Coil??
Old Jul 28, 2008 | 09:25 PM
Crazy Canuck's Avatar
Crazy Canuck
Default Coil??
I have a 95" sport/touring package from HQ on my
carburated 2005 Deuce. HVP heads, 575 cams, DTT/HQ
6104 ignition, Wiseco forged 10.5:1 compression with
releases and a Mikuni HSR 42 with the HQ tune kit. As
you can see. I still have my stock coil on the bike. I'm
thinking it's a weak link in the chain. Should I change it
or is it just fine??
I was looking at the DTT coil part # 2008. Any suggestions
would be greatly appreciated.
&nbsp\\;
Old Jul 28, 2008 | 09:51 PM
markymark02's Avatar
markymark02
Default RE: Coil??
your stock coil should fine, I've been using the stock coil with almost the same set up for about 3 yrs
Old Jul 30, 2008 | 05:24 PM
trafficjams's Avatar
trafficjams
Default RE: Coil??
DTT itself, in its TCFI ECM installation instructions states: Fuel injected Twin-Cam engines require a special coil with low primary resistance and an additional terminal for ion-sensing. Do not attempt to use any aftermarket coil.
Old Jul 30, 2008 | 10:27 PM
Crazy Canuck
Default RE: Coil??
Trafficjams,
My bike is carburated. Well for 75.00 bucks, I decided to
order it and try it out. Should be getting it this Friday or early
next week. I'll let you know if it does anything differant.......
&nbsp\\;
High Output Coil for Twin- Cam 88ÂŽ
Part Number 2008
[blockquote]
¡ Fits most 1999 and later carbureted models - same size as stock coil P/N 31655-99 (will not fit in place of P/N 31639-99)&nbsp\\;\\\\\\;
¡ Greater than 50 mJ and 40,000V output for demanding performance applications
¡ Compare to Screamin' EagleŽ coil P/N 31704-99 - same size and electrical specs at a substantially lower price![/blockquote]
Old Jul 30, 2008 | 11:34 PM
trafficjams
Default RE: Coil??
well oh dopey me
ORIGINAL: Crazy Canuck
Trafficjams,
&nbsp\\;\\\\\\;
Part Number 2008
[blockquote]
¡ Fits most 1999 and later carbureted models - same size as stock coil P/N 31655-99 (will not fit in place of P/N 31639-99)&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;
DK Custom - ST
Vendor For Sale Classifieds
Nov 26, 2018 12:49 PM
fatmanontwowheels
Oct 23, 2018 09:35 AM
charlesrt88
Shovelhead
Oct 11, 2015 02:45 PM
Danofxdx
Jan 10, 2013 09:31 PM
fatboyfrankster
Sep 13, 2007 12:47 AM
