Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
My last software version required running engine to about 285 degrees as part of initializing. I can't find ref to this in the 2008 version I have now. Did they do away with this requirement and only go with the 30 seconds on/off x3 as the only method now?
Ron
I've read that several times in the old software. Damned if I can find that in the new. I'm either getting blind, or they did away with the run to temp part on first start up.
Ron
When I installed my last Tmax tech said I would just need to cycle the switch and be done but my instructions said to run at idle for the final stage. I was confused but went ahead and did the idle thing like old and have had no problems (knock on wood!!!) : )
I agree with the run it to temp on first run for the time being, as it can't hurt anything. I just find it odd that there is no mention of this in the latest and greatest software. Previous software made mention of it many times, even in trouble shooting section. I was curious if it was an oversite in the manual or over time they've found the (run it to operating temp) unnecessary and the 3 on , off cycles good enough. Time will tell.
Ron
When I was at sturgis, I asked the tech there in the tent because I had heard that on another forum that it was gone and he told me yes it was gone and no longer necessary that it would adjust itself. Todd
