2007 softail pinging.
Old Sep 8, 2008 | 07:06 AM
augiedog's Avatar
augiedog
Default 2007 softail pinging.
Sorry to those who replied to previous post, we had a family emergency and have'nt been able to reply.
Our 2007 injected night train started pinging a couple of weeks ago. It will ping when I roll into it hard in 3rd gear starting about 2500 rpm's. In the morning riding to work when it is cooler it is not nearly as bad, but comming home when the motor is nice and hot its more noticeable. The bike has the stage 1 download, sreamin eagle air box kit, and vance and hines staggered short shots. I have read about possible causes such as a bad map sensor, or a bad crank position sensor, bad gas, weak plugs, wires, etc.We have been through a couple tank fulls of gas. How can you check the map sensor or crank sensor? Is there a way to check timing with a timing light, to eliminate possible crank sensor? Any suggestions will be appreciated!
Augiedog.
Old Sep 8, 2008 | 10:52 AM
LilBudyWizer's Avatar
LilBudyWizer
Bad gas is the most likely explaination. If you refill at the same station, or stations supplied by the same distributor, then refilling doesn't eliminate bad gas as the cause.
Old Sep 8, 2008 | 11:33 AM
bdavis385's Avatar
bdavis385
In my case it was "bad gas." It was a lower octane that was in the hose. I know stay away from stations with only one hose for three grades of gas.
Old Sep 9, 2008 | 07:02 AM
augiedog's Avatar
augiedog
We have filled up at different stations, to eliminate that possibillity. Did not think of the one pump hose for all grades of gas, good thought.
Augie.
Old Sep 9, 2008 | 12:02 PM
whittlebeast's Avatar
whittlebeast
I have a rock stock 2007 Sportster that rattled like a can of marbles on 93 fuel at 1/2 throttle or more any time the air temp was 90 or more. The www.nightrider.com ViEDs set to 14 AFR flat cured it.
AW
Old Sep 9, 2008 | 02:34 PM
LilBudyWizer
Well, by the service manual:
1. Fuel octane rating too low
2. Faulty spark plug
3. Incorrect spark plug for kind of service
4. Excessive carbon deposit on piston head or in combustion chamber
5. Ignition timing advanced due to faulty sensor (MAP and/or CKP)
Now personally, with that last one, I'm inclined to think you're going to have more problems than simply pinging at 2500 rpms at wot.
mynzbtr1
Oct 1, 2012 10:15 AM
waldhorn
Carburetor Related
Jun 11, 2012 01:59 PM
beerun
Road Trips
17
May 30, 2010 09:19 PM
sonic
Jun 21, 2008 10:26 AM
Luther OBanion
Mar 28, 2008 08:59 PM
