Starter MAP file?
Old Jan 10, 2009 | 01:10 PM
ssfirefighter's Avatar
ssfirefighter
Default Starter MAP file?
I went ahead and ordered my Doherty PP and my MasterTune. They should be here anyday now. And as soon as the new D&D pipes are ready, they will be here as well. I am planning on going up in cubes here soon, but went ahead and started with the other parts to get ready for it.
Now I am looking for a tune for the '09 with the high flow and the pipes to hold me over until the new motor and dyno tune. Does anyone have a good MasterTune file I could use until then?
Old Jan 10, 2009 | 07:05 PM
ronyd's Avatar
ronyd
This is what Jamie from FuelMoto says about TTS Tuner when I asked how do you determine which map to use:
"As far as determining your calibration when you load the TTS software there is a copy of the calibration #s with a breakdown of the specific model and specs they are for in PDF form stored in the program folder. The calibration list as well as the actual calibrations are updated everytime you run the TTS update."
Hope this helps a little. Maybe Steve Cole or Jamie can turn you on to a specific map here.. Good luck..
Old Jan 10, 2009 | 09:42 PM
ssfirefighter
Thanks. I haven't looked at the program files yet. I didn't know they were listed with descriptions.
BlackBastard
Apr 13, 2016 06:44 PM
472viper
26
Jan 6, 2015 04:23 PM
VETERAN75
Mar 16, 2014 10:24 PM
Nor Cal Mafia
Feb 19, 2012 08:23 AM
harry.b
27
May 28, 2010 08:36 AM
