Spark Plugs
Old Jan 15, 2009 | 03:08 PM
falbound5's Avatar
falbound5
Default Spark Plugs
I just did the 1000m service on my 09 Sg, when I checked the plugs the front one was black and the back one still basically white, any ideas or is this normal
Old Jan 15, 2009 | 08:04 PM
Crazycalvin's Avatar
Crazycalvin
I would not call it normal. What are your "build" details?
Old Jan 16, 2009 | 04:08 PM
falbound5's Avatar
falbound5
Everything is still stock, should I take it back to the dealer B4 I add pipes and a/c
Old Jan 16, 2009 | 05:38 PM
miacycles's Avatar
miacycles
If it is a dry black then it sounds like an injector or vacum leak problem. If it is a wet black then it is probably a ring/valve seal (oil) problem. Hope this helps.
Old Jan 16, 2009 | 08:18 PM
falbound5's Avatar
falbound5
Yes its a dry black, Ill take it back, Thanx
christneo
Exhaust System Topics
Apr 22, 2017 02:35 PM
active1951
Engine Mechanical Topics
Apr 20, 2017 04:03 PM
Bobber97
EVO
Apr 24, 2013 03:11 AM
Dumai
Jun 6, 2010 05:20 PM
DrRude
Aug 26, 2009 08:23 AM
