Tach needle bounce
Old Mar 24, 2009 | 05:05 PM
AR-15 DEUCE's Avatar
AR-15 DEUCE
Default Tach needle bounce
Was just seeing if anyone has had this,my tach has been on for 5 yrs.I have triple checked all wires.the thing is when my bike goes up in rpm anything past 4000 the needle jumps around,like 4000-43000 4000-45000 and I stay at the same rpm it works great from 0-4000.I have lived with it just wanted some feedback..thanks
Old Mar 25, 2009 | 12:39 AM
LilBudyWizer's Avatar
LilBudyWizer
I'm inclined to think the tach is defective, but it could be over-voltage at high rpms. The faster the engine speed the more power put out by the alternator and that may be overwhelming the voltage regulator at high engine speeds. Maybe use a digital multimeter that will capture peak voltage to monitor the power to the tach.
Old Mar 25, 2009 | 07:03 AM
murphdog's Avatar
murphdog
I've had 2 Harley mini tachs that started acting erratic after a couple or three years. If that's what you have, you've done good to get 5 years out of it.
Old Apr 3, 2009 | 10:15 PM
oct1949's Avatar
oct1949
in the old days I believe there was a sending unit inside the tach and if it went bad it done the bouncing needle also...dont know if the newer ones have the same make up though.
Old Apr 4, 2009 | 12:27 AM
XLCR4GM's Avatar
XLCR4GM
I put a Harley Tach on my '99 XL883 and it worked for a few years and then it started the bouncing thing similar to what you have described. I have a '07 XL883 that has a Harley Tach and I put it on the '99 and it didn't bounce at all. I purchased another Harley Tach and mounted it on the '99 XL883 and it works just like it should. I think I remember the counter guys at the Harley dealer telling me that Harley only warrants the Tachs for about three months or six months and the Black ones were much more expensive than the Chrome ones were by almost $100.00. Your Tach is probably broken and will need to be replaced. Sorry.
HarDlife
EVO
Jun 27, 2014 08:43 PM
BOCAD
Nov 25, 2013 08:43 AM
cuda67bnl
May 18, 2010 10:24 AM
cuda67bnl
May 18, 2010 08:28 AM
introuble
May 14, 2007 05:12 AM
