Turn Signal Problem
Old Nov 6, 2009 | 08:32 PM
secooper's Avatar
secooper
Stage IV
Default Turn Signal Problem
Local HD shop replaced LED bulb in left front turn signal and now comes on automatically when ignition switch is turned on. Will go off when depress right turn signal button. Once off, will not turn back on when depress left signal button. Even replaced LED bulb with regular 1157 and same problem occurs. Any clues or previous experience with this?
Old Nov 6, 2009 | 08:49 PM
chester1957's Avatar
chester1957
I replaced the left turn switch to fix similar symptoms. Could also be a short in the wiring or turn signal module.
Old Nov 6, 2009 | 09:04 PM
2003Springer's Avatar
2003Springer
More than Likely it is turn sig module.
mgoldade
Jul 2, 2014 01:02 PM
stevel
Jul 25, 2012 04:51 PM
unclerogi
Jun 16, 2012 09:13 PM
joechief
Aug 11, 2009 10:15 AM
MOSTWANTED
May 22, 2009 03:23 PM
