LED stop/taillight
Old Nov 11, 2009 | 07:54 AM
izzyfutch's Avatar
izzyfutch
Default LED stop/taillight
I want to put a LED replacement in the stop/taillight of my '92 Sportster. I might consider a "blinking" one while on the brakes. Any suggestions? Will I need a load equalizer to do this?
Thanks.
Old Nov 11, 2009 | 02:07 PM
Ram's Avatar
Ram
Normally a load equalizer is only used on turn signals because the LED's when in the turn signal circuit do not draw enough current to allow the flasher ckt to make them flash correctly. When being used as a standard running light or a brake light you don't normally need a load equalizer because they are not going to be blinking or routed though the turn signal flashing ckt.
Now if you are getting an LED product that states it will flash in some pattern be it adjustable or not, then the ckt is already made for it to be a flasher when the brakes are applied and functions independently from the turn signal circuit.
Old Nov 11, 2009 | 02:27 PM
izzyfutch's Avatar
izzyfutch
Thanks RAM
SteddyTeddy
EVO
Jan 23, 2019 09:17 AM
Road Star
Electrical/Lighting/Alarm
May 24, 2014 06:31 AM
ndmick
EVO
15
May 10, 2014 08:12 PM
rdmption
Jul 13, 2012 12:54 PM
RobV10
Jun 28, 2012 12:47 PM
