Gerbing Dual Temp Control mounting?
Old Dec 10, 2009 | 09:51 PM
NYBagger92's Avatar
NYBagger92
From: LI, and New York, NY -- N 40 44.985 W 73 00.910
Default Gerbing Dual Temp Control mounting?
so i installed the battery harness for the system, and ran it out by the front of the saddle, right below the left side of the tank.
now i have the Portable Dual Temp-Controller, and i am looking for ideas on mounting it semi-permanently. i may opt for the permanent dual temp controls eventually, but i was given this, so i am going to try to make it work.
do any of you have any creative mounting set ups?
i was also given the little pleather holster for the portable dual temp controller.
i am going to try, and fashion a bracket of sorts.
any ideas....
thnaks in advance.
Old Dec 11, 2009 | 02:12 AM
Captain Itch's Avatar
Captain Itch
Sponsor
Here is what I did If you want a small piece of leather for free let me know I would be happy to send it to you..
__________________
www.Captain-Itch.com
Old Dec 11, 2009 | 03:37 AM
NYBagger92's Avatar
NYBagger92
very nice setup.
i like the way you did that.
could be another Captain Itch product.
Old Dec 11, 2009 | 06:10 AM
Sandcrab's Avatar
Sandcrab
Default Plastic Tie
I used a plastic strap tie around the fuel line to hold the power lead.
Old Dec 11, 2009 | 06:40 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by robreeny
...any ideas....
I brought the battery wiring harness up from under the right side of the seat...when not in use, I just tuck the harness behind the backrest,.
As for the temp controller, I had one of the permanent mounts on another bike and found I always ran the temp set to high.
With my Ultra, I decided to go with the Harley toggle switch just hanging under the right side of my jacket.
Hope that helps.
Old Dec 11, 2009 | 11:00 AM
NYBagger92's Avatar
NYBagger92
a little to far forward for me. i zip tied mine under the seat, so that it doesn't move around too much. i then ran it to just above the plastic heat shield, and it sits outta sight. there is a small plastic insert that works great to hold it in place.
the dual temp is what i am trying to find a neater arrangement for. Capt Itch seems to have a pretty good set up for it.
thanks all.
Old Dec 11, 2009 | 11:01 AM
NYBagger92's Avatar
NYBagger92
Capt Itch.
I sent you a PM.
thanks for showing that little do-dad.
Cafard
Feb 23, 2018 10:12 PM
Hey Man
Oct 22, 2015 06:13 AM
krw
19
Feb 18, 2010 10:41 AM
honkylips
Sep 9, 2009 09:44 AM
Johnny B Good
Sep 22, 2006 10:04 AM
