TTS map file
Old Mar 23, 2010 | 02:08 PM
FrankT's Avatar
FrankT
Default TTS map file
Hi Guys,
I am wondering if anyone has a TTS map file they could share with me that would match my build (or come close). I have an 09 Fatboy TC96 with V&H BSS pipes with quiet baffles and screamin eagle a/c with K&N filter. I loaded the base file from TTS and I have tried several times to V-tune the bike myself but I don't seem to be getting very good results. I may just have to get it dyno tuned, but I thought I would try here first. Thanks.
Old Mar 24, 2010 | 12:15 PM
FrankT's Avatar
FrankT
Ok, thanks anyway guys. Off to the dyno I will go.
Old Mar 24, 2010 | 12:30 PM
y2kflhr's Avatar
y2kflhr
just curious how it was running with the stock map? what was the problem with the vtune? I just put tts on my 09 ultra with a base map, it runs night and day.
Old Mar 24, 2010 | 02:31 PM
FrankT's Avatar
FrankT
It ran ok with the base map, but in following the documentation, I decided to try to tune it in to my engine build. There was no problems with how VTune worked, it was more of an issue with trying to collect all of the various RPM/Throttle positions that I had trouble with. After several rides I was still only collecting a very small amount of data.
Old Apr 7, 2010 | 06:16 AM
y2kflhr's Avatar
y2kflhr
I have done a few vtune runs since you posted this, and yeah man its hard filling in the blanks!
are you tuned yet?
Old Apr 7, 2010 | 02:00 PM
FrankT's Avatar
FrankT
I'm scheduled to have it dyno tuned next month. I don't want to screw with this thing all summer long. I will get the dyno tune done and then be able to enjoy it!
Old Apr 7, 2010 | 03:17 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by FrankT
...There was no problems with how VTune worked, it was more of an issue with trying to collect all of the various RPM/Throttle positions that I had trouble with. After several rides I was still only collecting a very small amount of data.
FWIW, the data collected (assuming the system was set up correctly) will only collect data in those areas that the bike was operated.
While that seems too simplistic, most riders do not spend much time in high throttle/high load areas so the data simply won't be there.
Hardly any of my vtune sessions ever hit cells above a throttle position of 40% or 5000 rpm's...and I hardly ever ride in those loads either.
A good dyno will get into those areas but if the bike is never ridden that way then the data is not of much use.
Good luck!
PEESKI
Oct 8, 2017 01:35 PM
scooper321
Sep 10, 2016 10:13 AM
Diverrick
The Dyno Room
30
Jul 30, 2016 09:35 AM
soft 02
May 25, 2013 10:16 AM
kdubcr250
Nov 25, 2009 09:00 AM
