TTS mastertune question
Old May 20, 2010 | 09:10 AM
pmcburne's Avatar
pmcburne
Default TTS mastertune question
A question for you TTS experts. I'm about to do my first data runs. The manual says to set AFR, set CLB, and disable PE. Is this supposed to be done in Mastertune or will I be promted to do this in datamaster? Thanks for your time.
Old May 20, 2010 | 01:07 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
All done in MasterTune.
Remember the system will prompt you to save the file under a new name and that's the one you'll load into the ECM for the first VTune.
Each time you make changes to the tuning file, the system will again prompt you to change the file name, write over the existing one, or disregard the changes.
Old May 21, 2010 | 08:07 AM
BLACKTOP GLIDER's Avatar
BLACKTOP GLIDER
Default TTS question
Is this TTS system the one that retunes the stock ECM and if so is it available for the Marrelli or Mannelli (however it's spelled) throttle body bikes. I have a 99 RG and I'm going to have it tuned. Presently I have on old 9 pin PC111 and the tuner said he doesn't have the equipment to tune that unit and I'll need a new one.
Old May 21, 2010 | 01:29 PM
pmcburne's Avatar
pmcburne
They have a part number for the Magnetti Marelli. Check their website.
Jun 23, 2015 03:21 PM
tscott38
Apr 9, 2010 09:06 AM
ssls6
Oct 15, 2009 06:33 PM
catalac
Jan 1, 2009 11:37 AM
rockon
Sep 24, 2008 03:12 PM
