SERT Data Mode
Old Aug 20, 2006 | 12:00 PM
mud's Avatar
mud
Default SERT Data Mode
I have the SERT on my 06 SuperGlide, VH ShortShots, SE intake with KN filter.
Jamie was good enough to send a map or two, and this was a tremendous
performance improvement over the HD download that was previous.
Tweaked the map a little to richen, no decel pop, and I want to work into this a little further.
Am I missing some of the potential of the SERT by not knowing how to work with Data Mode??
mud
Old Aug 22, 2006 | 06:34 PM
irlm1's Avatar
irlm1
Default RE: SERT Data Mode
hi
i only just getting into using sert, and if you can do the tweaks you mention, then data mode...well not sure if you mean performing a datamode run or analysing the data. - performing the run is easy.....and is in the sert manual....cant think of all the steps right now, but manual best guide anyway for sure.
analysing is the other bit, but again i imagiine if done tweaks already then you will find way thru that too.
i have used mine so far only to analyse decel popping. can clearly see the parts of the map table that i pass thru on decel when i am getting the pop, and have updated these areas to get some improvement. now those areas were fairly obvious anyway but the data is good to back up what you plan to tweak. (i still have some decel popping to remove)
next i plan to use it to look for knock detection to show areas where this is coming into effect to help improve bad running.....but will let someone else comment about that. (or do search an d you will see.
if this doesnt help. ...then at least it bumps the message up..!!...
p.s. i have begun working from the standard map for 1450 with se ac and se pipes (i have se ac and v&h slip ons)....is this the one you mean you began with or do you mean hd download seperate to sert?
swicegk
Mar 19, 2008 10:28 PM
dmhosting
Jun 18, 2007 05:23 PM
atncass
Mar 4, 2007 02:57 PM
CoolBreeze3646
Oct 1, 2006 11:30 PM
Heymikey
Sep 6, 2006 11:00 AM
