Speedo issues
Old Jul 28, 2010 | 11:44 AM
johnnyholmes's Avatar
johnnyholmes
Default Speedo issues
I recently replaced the guts of my transmission after an unfortunate highway happening. I got a hot deal on all the innards so I went for it. Problem is, my bike is a 95 and the new gears are out of an 05. Everything was the same size and lined up, only problem is that the pitch of the teeth on all of the gears is much finer, so the speedo sensor is reading that im moving much faster than I really am. Anyone know how I could fix this without putting the origional first gear back in?
Old Jul 28, 2010 | 02:21 PM
LilBudyWizer's Avatar
LilBudyWizer
You could change speedometers. Many aftermarket ones can be calibrated, but I don't believe the stock one can be. Basically you set how many pulses per mile. An electronic speedometer counts pulses and converts that to a voltage to deflect the needle. With EFI the ECM counts those pulses then reports it digitally to the speedometer. A speedo from a bike that transmission is for should show the right speed assuming it's counting teeth on the same gear. My '08 reads 4th.
Old Jul 29, 2010 | 09:45 AM
johnnyholmes
I didnt know it would be that easy. How would you calibrate it?
Old Jul 29, 2010 | 01:08 PM
hornhonker's Avatar
hornhonker
TTS can calibrate the newer bikes, not sure abt 95s. Email them with
the question.
Old Jul 29, 2010 | 03:20 PM
LilBudyWizer
I don't know. It might take hooking it to the digital technician. The manuals might say or it might be a tightly held secret only revelled to dealerships. It might not even be possible. Well, it's possible, you can build a circuit to do it if nothing else. If it can't be calibrated then there's a good chance someone built one and said, hey, this is handy, I could sell this.
PS: Speaking of which Dakota Digital sells just such a device.
samhallnc
Aug 6, 2018 08:39 AM
johangastorp
Electrical/Lighting/Alarm
Aug 19, 2015 01:02 PM
maverick101
Jan 29, 2009 01:28 PM
Zutroy
May 3, 2007 03:11 PM
100yrfatboy
Feb 20, 2006 10:10 PM
