Running Lean
Old Sep 13, 2010 | 04:25 PM
henrytaf857's Avatar
henrytaf857
Stage I
Default Running Lean
My 2008 Street Glide is showing sighs of running lean:
1. Spark Plug tip are white and ashy
2. Sputters when accelerating
3. Popping from the intake.
4. O2 sensor's are also white and ashy.
I bought the bike new...I had some screaming eagles installed before I took the bike home...an upgrade was mapped to the bike...since then, I have installed Rinhart true duals and a K&N intake. I did not have any problems after the installs...this problem started when I was coming up a steep hill with a rider...intake started to sputter in 1st gear.
Exhaust is not leaking...I replaced the plugs and wires...no intake leak
My question is, do I need it remapped or should I install a tuner?
Old Sep 13, 2010 | 04:42 PM
BlockHead96's Avatar
BlockHead96
Remap with a tuner/fueler. Stock maps/download calibrations, are essentially a stock calibration, which equates to lean. Wiz will likely see this and could explain more.
commander112
Oct 8, 2016 09:35 PM
vboxmark
Aug 25, 2015 10:10 PM
Tfree
Mar 16, 2015 10:15 PM
Romark
Mar 29, 2011 06:19 AM
chiefparry
Oct 14, 2009 09:42 AM
