Injector problem?
Old Sep 15, 2006 | 04:01 PM
bohica48's Avatar
bohica48
Default Injector problem?
Just bought a 05 FLSTCI with 8K on the clock, Stage 1 download, SE air box, and V&H Longshots. It idles fine, no back firing, but seems to stall (if that’s the right term) intermittently while cruising at steady speeds. It does this at any speed, but the rpm’s and exhaust tone seem not change when it does. Was thinking it may be an injector problem, but I’m no expert with this stuff. Added the Stealth DFO to get more fuel but that made no difference. Any ideas?
Old Sep 15, 2006 | 04:03 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Injector problem?
Check the ignition system (Secondary)... Plugs and wires..... Could be a broken insulator on the plug.... Remove a plug and shake it...If it rattles it's done....
Does it feel like it's "Breaking Up" at throttle?
Old Sep 15, 2006 | 04:23 PM
bohica48's Avatar
bohica48
It seems to accelerate smoothly when you hammer it. I will check the plugs and wires when I get home tonight.
Thanks,
jrtrpp
Sep 9, 2017 08:13 PM
vboxmark
Aug 25, 2015 10:10 PM
ToadsUltra07
Apr 15, 2015 09:45 AM
niknog
Exhaust System Topics
Nov 28, 2011 05:29 AM
chordstrummer
Jan 18, 2011 06:02 AM
