Battery Tender question - quick
Old Jan 27, 2011 | 05:11 PM
JustDave71's Avatar
JustDave71
Default Battery Tender question - quick
Got a Battery Tender Jr here, no instructions
Do I connect the negative connector directly to the battery negative post or to frame ground?
thanks
Old Jan 27, 2011 | 05:17 PM
JustDave71's Avatar
JustDave71
nevermind. found it online.
connect to frame or use extension if connecting directly to battery?
why is that?
Old Jan 28, 2011 | 01:22 PM
snowmass's Avatar
snowmass
The reason is that you can make a small spark when making that second connection. You don't want that spark anywhere near the battery, explosive gasses there.
Old Jan 28, 2011 | 02:04 PM
jeff.georgalas's Avatar
jeff.georgalas
Mine are all connected to the battery. Never had a problem with it.
Old Jan 28, 2011 | 10:29 PM
snowmass's Avatar
snowmass
Yeah both sides of the harness of my battery tender are connected directly to the battery like yours. You hook that up first and then plug the harness to the power pack. You can't make a spark just hooking up a disconnected harness as far as I know.
I think the directions say to connect to the frame to be very cautious, I guess because some people might have the thing hooked to the power at the same time. I've seen big sparks come off of connected jumper cables, and I work with a couple of auto techs who have seen battery explosions in their shops. It'a a low frequency risk but ugly if it does ignite.
Old Jan 29, 2011 | 07:44 AM
Mr. Wizard's Avatar
Mr. Wizard
You can use the connector to find 12v for other situations such as heated gear or powering tuning equipment. If tuning, you need it to the frame as some manufacturers will tell you.
You can also use that connector to charge another bike while on the road. When doing that to a car or truck I never hook up negative to the battery, always the frame.
6 of 1 and half a dozen of another... really may not matter at all.
Old Jan 29, 2011 | 11:16 AM
JustDave71's Avatar
JustDave71
thanks guys. already connected to frame. probably won't change anything, but do need to route the cable a little better. Not much room in there.
need a new battery, trickle charge or not. will do this summer.
rjg883c
Nov 20, 2014 06:27 AM
RandyMan
Sep 25, 2014 06:39 PM
CWDoc115
Feb 8, 2011 01:59 PM
mke125125
Jan 17, 2010 12:10 AM
ironmike41
General Topics/Tech Tips
Jan 5, 2009 09:56 PM
