PCIII Accelerator Pump
Old Oct 6, 2006 | 07:40 PM
Shrug's Avatar
Shrug
Default PCIII Accelerator Pump
I like it! Definite performance increase in terms of snap throttle response. Haven't ridden enough to determine the MPG hit yet but after 160 miles, it seems to be inconsequential. Setup is simple. Hook up the USB cable and set the throttle sensitivity, # of engine revolutions, and % of fuel increase. Takes about 30 seconds.
Old Oct 6, 2006 | 09:21 PM
Ned69's Avatar
Ned69
Default RE: PCIII Accelerator Pump
Exactly what does it do for you??
I've read about this feature on DynoJet's site, but still don't understand why it's needed.
Thanks.
Old Oct 6, 2006 | 09:30 PM
gabhart's Avatar
gabhart
It's compared to the carbureted muscle cars of the past....when you went WOT on one of those cars there was a separate "pump" or "shot" of gas which would give you almost instant throttle response for the quick acceleration that you would expect. If set up correctly it should give you the same type of response on your bike.
Not technical but I believe this to be correct.
Old Oct 6, 2006 | 10:57 PM
Shrug's Avatar
Shrug
That's basically it. I come from the thumper dirt bike world where a pumper carb was agreat asset to adding snap of the throttle. Dynojet basically fakes out the fuel injection system.
Rode out the last of the tank with the same gas mileage I usually get. I think I'll leave it enabled.
2008FLHP
Exhaust System Topics
Jan 12, 2008 08:51 PM
songsmith
Sep 26, 2007 09:24 AM
JLHOG
Jun 4, 2007 01:31 AM
usecotton
May 28, 2007 08:08 AM
Shrug
Oct 8, 2006 11:44 AM
