Ignition Timing
Old Jun 8, 2011 | 06:46 PM
ml crisis's Avatar
ml crisis
Default Ignition Timing
Finished a 96 cu in build and went to my local dyno guy. What is done is somewhat irrelevant to my question but use a PC5. He dialed in the front cyl AFR, then the rear and said done. I asked about ign timing and the response was "it's at 4 deg where they all want to be". I hate answers like that but I must admit it's running like a charm. New to the Harley world and interested in feedback. I guess I should mention it's probably what you would call a stage 2 to 3 build. Thanks in advance ( no pun intended).
Old Jun 9, 2011 | 05:53 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
You could probably do better on the timing. I don't know anything about the PC5 so I don't know if it is capable of adjusting the timing.
Old Jun 9, 2011 | 01:51 PM
harleytuner's Avatar
harleytuner
it is adjustable. When the table is set to all zero's it is not making any adjustments. Positive numbers are advanced and negative numbers are retarded in the speified areas.
petejoe43
The Dyno Room
Jul 10, 2017 06:51 PM
falconbrother
EVO
Nov 9, 2015 07:41 AM
hutch08
May 28, 2014 02:50 PM
hands for horse power
Jun 12, 2010 04:44 PM
hddave2
Aug 10, 2008 07:58 AM
