Tts ?
Old Jul 28, 2011 | 09:41 PM
RA51's Avatar
RA51
Default Tts ?
Updated my sert to tts. Have a 06 Night Train an installed the 02 sensors an wired to ecm. Using map CAE176-03, this is for a 96" but set engine displacement to 88.6. Is there a way to see the knock retard in the data log for where it may have retarded timing ? Have people had much success with adding 02's to the bikes that did not have them an using the TTS ? Did one data log an vtune this evening an will see how it works out.
Old Jul 29, 2011 | 01:09 AM
Lonewolf176's Avatar
Lonewolf176
Although you will see knock retard in a "generic data" log (default setting) it's better to actually collect "spark data". Once you have "saved the file", select "spark data" under the "data type" button on the "data recording control" window. This collects less data but at a faster rate. Adding the o2 sensors lets you do your own vtuning. Closed loop will compensate for different fuel qualities.
Old Jul 29, 2011 | 11:02 AM
RA51's Avatar
RA51
Did 3 vtunes today an everything is going smoothly. Just learning the TTS. Bought a netbook for the recordings an that is working well.
CobraEd
Sep 25, 2012 10:01 AM
Farklson
May 3, 2011 05:04 AM
marty442
Exhaust System Topics
Jan 14, 2011 05:55 PM
kwas
Jul 25, 2007 05:04 PM
WildBill2566
Mar 30, 2007 10:58 AM
