Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I bought a set of those type to use on a GL1000 project that I was doing.
They will work fine, but the mount is pretty cheap, and probably not compatible with the mounts on your bike.
I seperated the mount from the body, and used a drilled bolt to mount them with, so the wires would be hidden.
All in all they are of semi poor quality, compared to genuine HD parts or most other parts found
from kuryakyn, or others.
I would rate them a 5 out of 10..
But what could you expect for $9.95 anyway[8D]
Sure they will work. They are dual filament, and your stock lamps are single. One circuit is low intensity for running lamps, and the other is much brighter for turn signals and/or brake lights.
