07 Fatboy - No turn signals or brake light
I have a 2007 Fat Boy with a "no turn signals, no brake light" issue. (The running lights work, the signals do not.) The brake light WILL work with the ignition in accessory, however, the turn signals will not. I heard earlier from a member that there may be a turn signal module which controls both the brake lights and turn signals. I did some research and all I can come up with is some sort of add on module that is altering the signals in some way?
Just curious if anyone knows if there is a turn signal module on a stock 07 Fat Boy and if it controls brake and turn signal lights.
Any information will be appreciated.
Thanks...
