Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
i want to wire my gauge lights to come on when i turn switch to acc.so i can show blue lights in gauges right now the only one that lights up when you turn to acc. is the tach. should not be that hard but i am no mechanic looking for someone that has the know how! thanks
Can you be more specific, which gauges youd like to light up in ACC?
It looks like you have the following gauges: Speedo Tach Volt Oil Pressure Fuel Air Temp.
Looking at the schematics it looks like in ACC. only the Speedo will light up, all the others will be OFF is that true?
What you need to do is move all the backlighting bulbs of the gauges from the ignition Circuit to the ACC. Circuit. It is easier said than done, youll need someone with some knowledge and skills to do that without messing up all your wiring.
For someone who knows what he is doing it will take an hour to do it, including taking fairing off/on.
