Intermittant tachometer malfunction
Old Feb 5, 2012 | 08:58 AM
PghCycle24's Avatar
PghCycle24
Default Intermittant tachometer malfunction
The tach on my '04 Ultra Classic began acting up last summer. When the bike was started cold it would read the correct RPM. After 15-20 min of operation (outside temps 70-80) it would start reading 100-200 rpm lower than what I knew it should be based on speed and which gear it was in. I might note there were no performance issues. Power and fuel economy are unaffected. As I continued to ride, the difference became greater and greater, until I would be reading almost 0 RPM at idle. If I shut off the ignition and park it for a short time, it would read correctly again when restarted. I do ride sometimes during the winter, and it has not reoccurred when the outside temps have been in the 30's, or has only happened to a much smaller extent (only the 100-200 RPM drop) during the cold weather. Any ideas?
dwatkins
EVO
20
Jan 27, 2021 05:53 AM
rnl_1200C
May 16, 2017 03:18 PM
gotwages
Nov 29, 2015 09:38 PM
hitman02
Oct 2, 2012 08:35 AM
stroker1948
Oct 18, 2009 08:43 AM
