ECM Help
Old Mar 3, 2012 | 03:24 PM
Foot+3's Avatar
Foot+3
Stage II
Default ECM Help
I'm in the process of converting my 2001 RK to an Ultra Classic. I was told it was important to buy the complete wire harness for my year model, I did and the connection for the ECM will not fit my original ECM? I found an ECM online from a 2002 Ultra which appears to have the same connectors. Will I cause myself even more problems changing the ECM?
Old Mar 3, 2012 | 05:37 PM
scotty3's Avatar
scotty3
Yes..........2001 Touring had Magnetti Marrelli feul injection.
You have bought OR been sold a harness for a 2002 up bike that is why the connectors are different as the ECM went to Delphi in 2002
You could of course buy a newer throttle body but then you have to change air cleaner and the list will get bigger.
Tank, pump........all can be modified but you would be better getting the correct harness.
Old Mar 3, 2012 | 06:11 PM
Foot+3's Avatar
Foot+3
Stage II
Default ECM Help
Thanks scotty3, if I buy a separate engine wire harness will that solve the issue? Or should I search for a complete harness for 2001?
Old Mar 3, 2012 | 07:47 PM
scotty3's Avatar
scotty3
To be honest I am not sure.....I have only done conversions to carb from MM
I would think you would need the correct harness but maybe someone else knows something I don't.
TheMurf
Aug 24, 2018 03:22 PM
rickrobbins50@gmail.com
May 20, 2018 06:39 PM
kenlani
Aug 11, 2016 03:58 PM
ExtremeBaggers
Touring Parts
Jul 17, 2014 02:20 AM
handyman63
Electrical/Lighting/Alarm
Jun 26, 2010 08:53 PM
