PCV and AutoTuner question
Old Jun 4, 2012 | 10:02 AM
UncleMort's Avatar
UncleMort
Default PCV and AutoTuner question
I have tried to search and can't find the answer.
If you DO NOT add the switch, does the Autotuner stay in learn mode? or if not, how does it function versus the switch method?
Old Jun 5, 2012 | 01:02 PM
UncleMort's Avatar
UncleMort
No one has experience with PCV? I should have put "Laffing Devils" in the title...
Well, from what I have found out (using on my own), is that it stays in learn mode, and makes slight adjustments (+/- 20). Then, you plug into the unit, you can view the adjustments, and accept them if you wish.
izzyryder
Mar 4, 2014 08:23 AM
Krazy8s
Apr 3, 2013 02:39 AM
Bigiron
Sep 3, 2011 04:27 PM
1sweetglide08
Oct 4, 2010 11:52 PM
DrPlastic
Mar 16, 2010 06:58 PM
