Headlight wiring???
Old Jan 16, 2007 | 03:29 AM
Soarer's Avatar
Soarer
Default Headlight wiring???
Hello,
I just received my new headlight that I bought off of Ebay. I want to check it before it goes back in the box and sits for another month until the time when my front end gets re-done. I am only familiar with hot and ground in terms of lighting. It has a RED and Yellow wire, can I connect it to my truck battery? Or is the wiring different than hot & ground?
Old Jan 16, 2007 | 01:07 PM
twowheelsforever's Avatar
twowheelsforever
Default RE: Headlight wiring???
I believe the headlight unit itself is the ground, and one wire is hi-beam, and one wire is low-beam. I don't remember which color is which, but you should be able to easily test it. Just attach a ground wire to the headlight mount, and then alternate power to either wire to see which one is brighter.
Old Jan 16, 2007 | 08:00 PM
Soarer's Avatar
Soarer
Thanks for the info. Sounds like an easy one now that I know that. It's a real nice light for $100, on ebay.
Thanks
Old Jan 17, 2007 | 01:48 PM
twowheelsforever
Should be a piece of cake, but let us know if you run into any problems.
rjheff
Mar 11, 2011 08:27 PM
Motorhead England
Oct 27, 2009 04:03 PM
springerscott
Feb 10, 2008 12:14 PM
2007fxdc
Dec 27, 2007 03:23 PM
nightrain88
Mar 20, 2005 04:01 PM
