02 Sensor un plug
Old Jan 31, 2007 | 10:13 AM
ultra2006's Avatar
ultra2006
Default 02 Sensor un plug
How do you remove the wire from the 02 sensors, so you can remove them. Thanks
Old Jan 31, 2007 | 01:11 PM
grandpawmoses's Avatar
grandpawmoses
Default RE: 02 Sensor un plug
IMHO, the O2's are important and shouldn't be taken from the system. That said, the connections are located in hidden places. On my Fatboy, the fromt connection is located behind the regulator (access by removing two screws & swinging the regulator down & out of the way). The rear connection is clipped under the oil tank.
Old Jan 31, 2007 | 01:23 PM
ultra2006's Avatar
ultra2006
we are changing out exhaust they will be re installed, just need to undo the wire from teh sensor.
Old Jan 31, 2007 | 02:27 PM
nvsteve's Avatar
nvsteve
Just follow the wires from the 02 bung until you find another connector.
On my bike they were less than a foot away.
You can easily disconnect and leave the sensors on the headers until
you get the headers off.
There were some tie downs that are easily removed as well.
mrfatboylo
Mar 12, 2017 12:47 PM
dyna rider
Sep 10, 2013 03:40 PM
boulevard789
Electrical/Lighting/Alarm
Dec 19, 2010 12:36 PM
AFblacksheep
Mar 15, 2010 06:19 PM
gregski
Exhaust System Topics
Feb 12, 2009 08:09 PM
